Re: Cut out and polarization
Posted by Tim Daley(MI) on April 15, 2020 at 07:25:20 [URL] [DELETE] :
In Reply to: Cut out and polarization posted by Ed Douglas on April 14, 2020 at 15:35:29:
HiYa Ed- Hope ya'll are safe and healthy.
Did you test the new battery for a full sustainable charge and specific gravity level? Even a new battery can be junk out of the door. Does everything work fine? Does the AMMETER show a + charge when running? Does generator have a belt tensioning device? If the wiring is all correct and all runs fine, relax, should be fine. A cutout signifies a 6V/POS GRN setup as you know. A weak arc-spark probably means the system is A-OK. Maybe JMOR, Bruce(VA), or Soundguy can chime in.
`FORD TRACTOR 9N-10505-B CUTOUT CIRCUIT TEST:
FORD TRACTOR 9N & 2N OEM 6V/POS GRN WIRING:
FORD 9N/2N TRACTOR ESSENTIAL OWNER/OPERATOR/PARTS/SERVICE MANUALS:
