Re: Pump base bolt torque specs
Posted by Tim Daley(MI) on April 20, 2020 at 05:23:50 [URL] [DELETE] :
In Reply to: Pump base bolt torque specs posted by Travis Webb (UT) on April 19, 2020 at 23:21:22:
Travis-
BOTH. Torque is applied to the FASTENER, not the part that it is fastened to. The pump base is secured with part number 355693-S7, 7/16-14 x 1-3/8" Hex head bolts with a plain steel flat washer (p/n 351428-S7) used only with the aluminum base. You are torquing the bolt.
