Re: Wagner f.e.l. spool rebuild question
Posted by TheOldHokie on April 24, 2020 at 12:05:48 [URL] [DELETE] :
In Reply to: Wagner f.e.l. spool rebuild question posted by Beth and Allen on April 24, 2020 at 09:12:53:
I assume you mean valves not just the spools. The valves are not rebuildable and AFAIK replacement parts are not available. New two spool valves are inexpensive and available from any number of sources. The main "complication" you will run into is the Wagner lift cylinders are single acting and OTS two spool valves are typically double acting on both spools. You can use a double acting spool to operate the single acting cylinders by teeing the unused work port back into the tank return line.
TOH
