Hey Old Hokey,Good to see you on here.
Posted by Beth and Allen on April 24, 2020 at 15:52:18 [URL] [DELETE] :
In Reply to: Re: Wagner f.e.l. spool rebuild question posted by TheOldHokie on April 24, 2020 at 12:05:48:
I'm guessing you mean the cylinders only work one way,Ex power lifting gravity down. If so mine work both directions so "correct me if I'm wrong" mine are double acting,push and pull. Hydraulics isn't something I've had much experience on, so I'm going on a dash of common sense and a lot of ok lets try this. Again correct me if I'm wrong but I thought the lever and valve body assembly that operate the cylinders was called spools,either way mine are not so good and I've got to replace or rebuild and I value your input on this. Thanks and God Bless, Beth and Allen.
