Re: Gasoline suggestions?
Posted by Brad on April 27, 2020 at 17:44:19 [URL] [DELETE] :
In Reply to: Re: Gasoline suggestions? posted by Bruce (VA) on April 27, 2020 at 10:37:22:
Good to hear what works out well for you Bruce.
Last year all my small engine carburetors were wrecked by ethanol in the regular gasoline that I used.
Mostly I was able to repair (had to replace one carburetor, couldn't clear crud from passageways) and remove corrosion caused by ethanol attacking the metal inside carburetors, and get my older equipment running properly.
Afterwards, in my small engines, I ran strictly ethanol free gasoline to avoid this headache, and followed proper Winter storage procedures.
I'm quite pleased to learn your method using Marvel Mystery Oil in the gasoline, and brand of fuel stabilizer which you've had good luck with.
There was a cost in time and expense dealing with carburetors, which I am not eager to repeat lol :-)
