Re: Bendix keeps breaking
Posted by Tim Daley(MI) on April 28, 2020 at 07:49:36 [URL] [DELETE] :
In Reply to: Re: Bendix keeps breaking posted by Chad Stevens on April 27, 2020 at 11:43:45:
Yes, converting back to the OEM 6V/POS GRN setup is doable providing you have all the correct components -generator, voltage regulator, battery, wiring et al. Shortcuts are not an option. Are you certain you are using the correct starter Bendix? Are you certain your 12V setup is wired correctly? I'd verify what you have now is correct before making any changes. I suspect something else is wrong.
FORD OEM 600/800 WIRING DIAGRAM; 6V/POS GRN:
FORD 600/800 TRACTOR IGNITION TIMING & ELECTRICAL WIRING:
FORD 600-800-900 12V SWITCHOVER:
