Howse & Hico 500 Rotary Cutter Blade Bolts
Posted by lyle on April 28, 2020 at 11:32:32 [URL] [DELETE] :
Wondering if anyone has a 'trick' to remove these bolts. I want to replace or sharpen blades, I'm reluctant to sharpen without removing them, because of difficulty accessing blade edge with grinder underneath mower.
I've tried the PB blaster soak/wait/pneumatic tool/soak/wait....etc etc.
Next up is tacking blade bolts to blades underneath and using big ole breaker bar or removing the whole Flywheel Assy which is corroded as well.
Threads on all 3 bolts are visible but corroded as mentioned.
I've tried all the common sense,obvious methods as I mentioned. Thanks
