Re:Back To OldHokie
Posted by TheOldHokie on April 30, 2020 at 17:46:02 [URL] [DELETE] :
In Reply to: Re:Back To OldHokie posted by Beth and Allen on April 30, 2020 at 17:29:03:
According to the manual the models with single acting lift cylinders did not use that valve. I doubt you will need it with a new 10 GPM pump and valve that you can feather. If you can measure the bore and stroke of the dipper stick cylinders I can calculate the lift time at 10 GPM:
TOH
