Re: To lyle about cutter blades
Posted by Dn-N-Tn on May 02, 2020 at 09:28:04 [URL] [DELETE] :
In Reply to: Re: To lyle about cutter blades posted by beth and allen on May 01, 2020 at 12:43:28:
I never take my blades off to sharpen them----I unhook the center link---take the cherry picker and chain---hook the chain to the trailing wheel bracket---leave the PTO and everything else connected---jack up the rear of the bush hog till the PTO shaft almost makes contact with the 3-point hitch---rotate the stump jumper till I have a blade at the rear---use a small piece of 2x6 to foul the blade and go to work with my grinder. Works good for me and is a lot quicker than trying to get the bolts out, Dennis.
