Re: Need help finding somethings
Posted by Tim Daley(MI) on May 02, 2020 at 09:29:05 [URL] [DELETE] :
In Reply to: Need help finding somethings posted by Beth and Allen on May 01, 2020 at 17:46:34:
Paint is no problem to locate. I buy my TISCO stuff at a few local tractor yards or the CNH IRONGARED stuff at my local CNH dealer OR Just8Ns sells the TISCO stuff as well. Repop ID Tags can be found at George Bradish in Latrobe, PA -see LINK. Call George & Brenda and talk. If they don't have your tag George might make one if you send him the original.
The general rule of thumb for Ford Tractors is: cast iron = M-2822, Vermillion (red) enamel, and sheet metal = Ford Medium Grey, M-13243, and Black is Ford M-2824 , a semi-gloss enamel. Seat and spring, radiator, rad cap, steering wheel spokes, are black. Radiator shroud and fan blades are red. Starter and generator were red but black is OK too.
The TISCO brands come real close to the OEM. Use the IHC TP-110 for red; it comes closest to OEM Vermillion. TISCO sells other Ford Reds that are supposedly correct for the Hundred Series with more orange in them but I donít care for them personally. Check with JUST8Ns for their inventory if you canít find locally. CNH sells the Iron Gard brand and will be OK too. You can get it in Red, Med Grey, and Black. There are others too, Iím just saying what has worked best for me. Your tractor, paint it any colour you like.
For hat rims and wheel nuts I use the Case/IH Silver Argent wheel paint. For throttle and plate, gas tank, and acorn nut and washer I use Eastwood Silver Cad.
