Re: Dirt Scoop - Which way should it face? Stabalizers?
Posted by Tim on May 07, 2020 at 16:55:11 [URL] [DELETE] :
In Reply to: Re: Dirt Scoop - Which way should it face? Stabalizers? posted by Dean on May 07, 2020 at 14:04:25:
If it's a Ferguson earth scoop yes you pull it and you should have a chain or bar to keep it centered. Set it so you can dump it and lower the scoop in dump mode then you can scrape with it. Play around with the angle it set if you lower it about 2 inches and set it parallel to the ground it will level Not dig adjust slightly down at the front you can bury it so adjust you depth limit. You will love it once you play with it awhile
