Re: Governor cap
Posted by Jock(OR) on May 11, 2020 at 00:21:10 [URL] [DELETE] :
In Reply to: Governor cap posted by Jessie Peterson on May 09, 2020 at 07:53:28:
It is properly called a tachometer drive cap (or cover), and is the same size and threads as the older speedometer drives. Years ago I had some that were WWII surplus from Continental aircraft engines. That supply has dried up now.
In the short run, use a "Cap plug", which is a red plastic cone with a flange on it. They are available in all sorts of sizes, and are tapered inside and out. Find one that the internal taper will slip onto your tachometer drive threads.
I believe the aircraft caps are still available, but the price is over $20.00!
