Re: 9N Oil Canister
Posted by Tim Daley(MI) on May 17, 2020 at 07:14:48 [URL] [DELETE] :
In Reply to: Re: 9N Oil Canister posted by Bob on May 16, 2020 at 14:41:46:
Tom-
"...Have since found out that the hole size in the canister tube is 0.059 which is less than 1/32"..." -your words/post from above. Like I said, what, if any, issues are you having? Low or no oil pressure on gauge? Yes? Investigate why -bad gauge, plugged line. Not going to fix just by rebuilding oil pump, but you're half way to an engine rebuild when you drop the oil pan. I think you are concerning yourself over nothing and I wouldn't add any whistles and bells to a system that has worked for 80 years or more. Good questions Tom but advise you to move on.
