Re: Locked up motor after rebuild
Posted by Scott on May 19, 2020 at 15:17:20 [URL] [DELETE] :
In Reply to: Re: Locked up motor after rebuild posted by JMOR on May 19, 2020 at 12:44:22:
Yes the bolts are the correct length. The same ones that came out of the flywheel before the rebuild. This was a running tractor prior to the rebuild, just didn't have compression or oil pressure.
