Problem starting my 8N Ford
Posted by JIm Schroeder on May 21, 2020 at 15:47:14 [URL] [DELETE] :
My 8N Ford has always started fairly easily and runs good. It has a key starter switch and also a large push button just above the gear shift level. I always turn on the key and push the push button to start. Now I hear no sound and nothing happens. I replaced the solenoid and this did not help. I hocked up jumper cables to the starter and a ground and the motor will turn over. I have concluded the problem is in the push button starter; but in removing it, I see two points (?) and don't see any easy answer. Who can help me on this? If possible, call me at 405-615-5445. AN OKIE WITH A PROBLEM. tHANKS
