Re: Problem starting my 8N Ford
Posted by John in MIch on May 21, 2020 at 17:33:28 [URL] [DELETE] :
In Reply to: Problem starting my 8N Ford posted by JIm Schroeder on May 21, 2020 at 15:47:14:
Before trying to replace the starter button: have you cleaned the connection? The button provides a ground through the transmision case to the battery. Be sure to disconnect the battery first.
If it turns out to be the start button, it is easy to replace by removing the transmission top cover.
