Re: Choke
Posted by SteveVa on May 22, 2020 at 11:05:56 [URL] [DELETE] :
In Reply to: Choke posted by Ron on May 21, 2020 at 07:50:17:
My first thought is check for intake manifold leak. Spray wd40 or carb cleaner around joints and gaskets while running and see if idle changes. I am guessing you tried adjusting carb richness?? Choke won't help slow gas flow so your lines and tank seem to be fine. Good luck, I have run things with choke on many times trying to find a leak. Usually is an adjustment.
