Re: Shutoff valve
Posted by Gary in GA on May 23, 2020 at 23:14:01 [URL] [DELETE] :
In Reply to: Shutoff valve posted by Frank (WNY) on May 17, 2020 at 09:51:38:
I have the same problem. My original had so much corrosion in it I couldn't clean it. Seems the metal over the years deteriorated and blocked up the assembly. I opted to buy one from Steiner. The new one works just fine except for a leak where the glass bowl inserts into the valve body. No matter how much I tighten the thumb wheel it leaks. Apparently the cork gaskets these days are not like the originals. I need to find a way to seal it better before I have a fire on my hands. Open to suggestions....
