Re: Shutoff valve
Posted by Frank (WNY) on May 24, 2020 at 11:05:00 [URL] [DELETE] :
In Reply to: Re: Shutoff valve posted by Gary in GA on May 24, 2020 at 08:30:28:
Everything around the bowl assembly was tight and no external leakage. I wouldn’t have found the leakage through the valve if I hadn’t seen it dripping around the fuel line flare fitting going into the carb fuel filter. Luckily I had just cleaned and rebuilt the carb so it wasn’t flowing into the engine.
