Re: Whaley
Posted by Tim Daley(MI) on May 25, 2020 at 05:42:03 [URL] [DELETE] :
In Reply to: Whaley posted by Lee on May 24, 2020 at 13:46:48:
HiYa Lee-
Unsure what you mean about "times 180 opposite of manual". There's only one correct way to set the timing on the front mount and if it is bolted in 180 off, it will bust the aluminum base as shown in picture. Timing is set according to manuals -or by a timing gage -see pictures. Condenser mounts as shown with unit so guts are exposed, clamped on LH and wire thru on the right. Just to be sure, is it wired correctly? OEM Ballast Resistor in place, no gen or VR; 12V bat, alt, and coil; NO external resistor? Do you have a copy of WIRING PICTOGRAMS by JMOR? If not go to our HOW-TO's to download a copy.
FORD N-TRACTOR FRONT MOUNT DISTRIBUTOR:
HOW TO SET TIMING:
RESULTS WHEN UNIT IS MOUNTED 180 OFF:
FORD 8N-SERIES TRACTOR OEM 6V/POS GRN WIRING PICTOGRAM:
FORD 8N-SERIES TRACTOR 12V CONVERSION; FRONT MT. WIRING PICTOGRAM:
FORD 8N-SERIES TRACTOR 12V CONVERSION; ANGLE MT. WIRING PICTOGRAM:
