Re: 8N tractor difficulties starting.
Posted by Brad on May 25, 2020 at 09:44:08 [URL] [DELETE] :
In Reply to: Re: 8N tractor difficulties starting. posted by Tim Daley(MI) on May 25, 2020 at 04:46:53:
You are correct Sir! Good information as always Tim :-)
Start-Up Checklist
1. Make sure you've had coffee
2. Turn fuel on
3. Insert ignition key (leave switch off)
4. Move throttle open 1/4
5. Ensure transmission is in neutral
6. Ensure PTO is disengaged
7. Check position of 3-point lift lever
8. Depress clutch
9. Turn on ignition key switch
10. Push starter button for 1se-2se
11. While running starter, briefly pull out choke lever
12. Push choke back in, engine starts
One could add more items to list but I didn't want number 13 with my luck ;-)
https://drive.google.com/file/d/172PgonF2PSU-lxaR9I2iDb2_FIyE8Ljn/view?usp=sharing
