Re: 8n hydraulic problem
Posted by TheOldHokie on May 26, 2020 at 06:00:21 [URL] [DELETE] :
In Reply to: Re: 8n hydraulic problem posted by Mitchell on May 25, 2020 at 17:47:38:
If you can push the arms down you have a leak somewhere in the lift circuit. Most common source is the lift cylinder - much easier and cheaper than the pump. Another possibility is a sticky/dirty control valve or pressure safety valve in the base of the pump. I'd do some basic internal inspection including a hard look at both before I jumped into a full overhaul of the pump.
TOH
