Re: Made You Proud!
Posted by Tim Daley(MI) on May 29, 2020 at 05:39:09 [URL] [DELETE] :
In Reply to: Made You Proud! posted by Jim Lawrence on May 28, 2020 at 09:58:20:
HiYa Jimbo, good to see you again. Just a few things you should have tried first before buying a new battery. Did you get it tested first? Do you use a float charger such as the Battery Tender when tractor is not used for a week or longer? Going thru the entire wiring setup too is important -correct, clean, and tight. Having the correct battery cables - a 12V is different than a 6V system. Just suggesting some FYI for future reference.
