Re: Nakamura
Posted by TheOldHokie on May 31, 2020 at 07:50:35 [URL] [DELETE] :
In Reply to: Nakamura posted by Jack on May 30, 2020 at 20:29:04:
FORD Model 19-97 industrial loader. You will be looking for used parts or fabricate your own:
  1. The front hanger is a simple piece of steel plate with some drilled/sawn holes.
  2. Threaded rod or long cap screws and tube spacers for the struts.
  3. A pump mount can be made from some angle iron and a standard pump mounting foot bolted/welded to the plate.
  4. The rear brackets are a little more of a challenge but not terribly hard for a good fabricator to make.
TOH
