Re: Solonoid on 9N
Posted by Bruce(VA) on June 03, 2020 at 05:38:10 [URL] [DELETE] :
In Reply to: Solonoid on 9N posted by pete on June 02, 2020 at 20:17:04:
2 and 9Nís did not come from the factory with solenoids. They all had mechanical starter switches. When you press the starter switch, it pushes a piece of linkage into the switch which manually closes the contacts and completes the circuit. Unlike a solenoid which electrically closes the contacts and completes the circuit.
Are you asking how to replace the mechanical starter switch with a solenoid?
If so, you will find out that it's cheaper and easier to fix the mechanical switch.
