Re: Ford 8N fan blade
Posted by Tim Daley(MI) on June 07, 2020 at 07:17:24 [URL] [DELETE] :
In Reply to: Ford 8N fan blade posted by Matthew on June 06, 2020 at 18:51:11:
If radiator rubber supports are not correct or missing and/or radiator is tilted as mentioned, the fan shroud may interfere. I highly recommend to leave the fan blades alone and if you can't get it to work with the shroud, just yank it off and leave alone ALL 9N's never used a fan shroud and worked just fine. They were supposed to be for more suction to direct warm air flow towards the operator in cold weather. I found only aftermarket units caused interference.
