Re: New gas leak
Posted by Frank (WNY) on June 09, 2020 at 08:19:06 [URL] [DELETE] :
In Reply to: Re: New gas leak posted by K.LaRue-VA on June 09, 2020 at 07:30:45:
The leak is coming right under the threads where the flare fitting enters the valve assembly. I just removed the line this morning and the end that goes into the elbow at the carb looks smooth and shiny. The end that is leaking looks a little rough. I will try to look at the seat next to see how that is. I used gasoila to seal the assembly to the tank and everything is dry.
