Re: New gas leak
Posted by Frank (WNY) on June 10, 2020 at 06:03:30 [URL] [DELETE] :
In Reply to: Re: New gas leak posted by Tim Daley(MI) on June 10, 2020 at 05:17:17:
Hi Tim, I bought the parts from just8nís last fall when I discovered the leaking valve which I also bought from them 2 years earlier. I usually buy everything for this tractor from them and have never had any problems before with either parts or service. Now that I have figured out whatís happened i will contact them. I was just curious if anyone else had seen this problem with the valve. If nothing else in the fuel system is not leaking and the carb float is working properly you wonít notice the valve leak.
Thanks, Frank
