Re: New gas leak
Posted by Tim Daley(MI) on June 10, 2020 at 06:19:19 [URL] [DELETE] :
In Reply to: Re: New gas leak posted by Frank (WNY) on June 10, 2020 at 06:03:30:
If your Bulb Assembly leaks when the glass bowl is off and Shut-Off Valve closed, the problem is in the valve stem. Could try a different supplier -look for the TISCO brand. Your carb should be fine for now, you can always rebuild it if it's been a while once you fix leaking issue. If no gas evident in carb air intake throat when rubber hose removed, float should be OK too.
