Re: 9n wont turn over
Posted by will on June 10, 2020 at 12:50:57 [URL] [DELETE] :
In Reply to: Re: 9n wont turn over posted by Jack - Iowa on June 10, 2020 at 07:12:27:
Starter is good and has been tested. I checked volts from starter post to ground on battery and got 12+ volts. I took the starter off several times and turned over the flywheel to get a new spot for the bendix because I thought maybe ring gear is worn out?
