Re: 9n wont turn over
Posted by Jack - Iowa on June 10, 2020 at 13:59:09 [URL] [DELETE] :
In Reply to: Re: 9n wont turn over posted by will on June 10, 2020 at 12:50:57:
But was that starter repainted? You must have an electrical connection from the starter case to the grounded terminal on the battery. That is the second half of your circuit. May have to scrape/sand some paint off. Also check for dirt/grease on the mating surfaces. You could try a jumper cable from the grounded post to the starter case if you have a place where bare metal is showing.
