Re: oil pressure
Posted by gary on June 17, 2020 at 08:52:05 [URL] [DELETE] :
In Reply to: Re: oil pressure posted by Bruce(VA) on June 16, 2020 at 09:20:45:
pump was producing 35 psi when i tore it down to replace badly worn crank. i packed the pump body with engine assembly lube and the tube with new gasket was firmly attached. took new pump to machinist but he said the pump was fine. this happened when i originally rebuilt motor, hence wasted crank.
