Re: 2N start button stopped working
Posted by Tim Daley(MI) on June 28, 2020 at 05:46:17 [URL] [DELETE] :
In Reply to: 2N start button stopped working posted by Steve Frysinger on June 27, 2020 at 14:55:29:
You need to perform true root cause problem solving methods before you start pulling parts off and replacing with new. Start with verifying wiring is correct and testing the battery at a reliable shop. A 6V (or a 12V) battery does not mean the system is wired correctly. Dead or weak battery is a he culprit for non-starting. How do you jump start your tractor? Do you have 1-Wire generator with a belt tensioner AND the cutout? The neutral safety starter pushbutton is NOT a solenoid. ALL the 9N/2N wiring diagrams are in the Essential Manuals; Owner, MPC's, and the FO-4 manual -got 'em? You can download the MPC's in our MANUALS forum. Here's a taste for you.
FORD TRACTOR 9N & 2N, AFTER S/N 12500, OEM 6V/POS GRN WIRING:
