Re: NAA Starting issues
Posted by Bob in KS on June 29, 2020 at 08:12:19 [URL] [DELETE] :
In Reply to: NAA Starting issues posted by Dan J on June 28, 2020 at 19:41:04:
6 volt or 12 volt conversion?
If it is a 12 volt conversion with an added resistor between the switch and coil try jumping across the resistor.
Some 12 volt conversion kits are supplied with a resistor with too high an ohms value.
If resistance between + and - on coil is about 1 1/2 ohms it should have a resistor of same approximate value.
If 3 ohms across coil do not use a resistor
