Re: mower
Posted by Tim Daley(MI) on July 12, 2020 at 16:37:41 [URL] [DELETE] :
In Reply to: mower posted by gary on July 12, 2020 at 14:15:10:
Most Rotary Mowers (Brush Hogs) are 60" and work fine. Popular brands are Bush Hog; King Kutter; Land-Pride; and more. I'd be sure your unit, new or old, has the stump jumper feature and parts are readily available. As John stated use an ORC and I'd also recommend to install STABILIZER BARS as well. If you do, know there is one correct way to install them -see our HOW-TO's. For heavy brush, may need to make two passes. Always scout the area you are mowing for any hidden objects - stumps, logs, rocks, cars, parts, bodies, Jimmy Hoffa, et al. 2nd gear 7/8 throttle normal for mowing but in heavy stubble may need to go down to 1st. That will also affect gas mileage/consumption as well but the trade off is you don't ruin your machines. Check your local CraigsList for what's out there.
