Re: 9N ?
Posted by JMOR on July 18, 2020 at 12:15:25 [URL] [DELETE] :
In Reply to: Re: 9N ? posted by Tiger Dobrenic on July 18, 2020 at 10:27:36:
Two on barrel should be Field(insulator under it) & Ground(no insulator). On rear is Armature. With the FIELD CONNECTION AVAILABLE, THE GENERATOR WAS DESIGNED FOR A VOLTAGE REGULATOR. Originally, it would have had one-terminal generator & used cut out. Someone has changed it over the last 60 years. Surprise, surprise!
