Re: NAA Starting issues
Posted by Richardny2n on July 19, 2020 at 14:57:56 [URL] [DELETE] :
In Reply to: NAA Starting issues posted by Dan J on July 19, 2020 at 12:20:50:
A guy I know wanted to sell an 8N to me. We pull started it and it sounded pretty good when running. I don't recall oil pressure. Any way I asked if a compression test had been run. He said no. Later we cranked the engine over and had numbers in the 30 range. I said no thanks. You might run a compression test. I have heard marvel mystery oil in the cylinders loosened stuck rings and improved compression.
