Re: 9N starting issues
Posted by K.LaRue-VA on July 22, 2020 at 07:29:40 [URL] [DELETE] :
In Reply to: Re: 9N starting issues posted by Evan (ND) on July 21, 2020 at 20:30:31:
The Zenith is a direct replacement. It looks a little different, but adjustment screws are in basically the same places and the procedure is the same as for the original carb. However, as Bruce indicated, "the" problem doesn't have anything to do with carb adjustments. If the engine isn't getting fuel, adjusting won't fix it.
