Re: Need a refresher/split 860
Posted by SteveVa on July 26, 2020 at 14:10:02 [URL] [DELETE] :
In Reply to: Need a refresher/split 860 posted by lonestarjeff on July 26, 2020 at 13:17:47:
With the starter off it wouldn't be the ring gear. Does ring gear drive a pump on those? What I do with MG's is to turn a back wheel with trans attached. Or just turn trans shaft if back end is not attached. Are there located pins?
Shake up and down and spin a wheel if you can. Good luck.
