Re: Looking for harrow parts
Posted by 49er swGA on July 27, 2020 at 09:34:42 [URL] [DELETE] :
In Reply to: Looking for harrow parts posted by 49er swGA on July 25, 2020 at 19:41:44:
As you can see, my computer skills have a great deal to be desired...
I totally messed up this posting by trying to get a picture through the link, BUT when I tried the link it was different than I had wanted to show > `twas the company BUT NOT the part...
I can find 7-1/2" X 1-1/8" square axle Bearing part BUT mine measures 6-1/2"...
Part numbers or casting numbers are PA3089 & P3091 on the bearing housing halves with the bearing/spacer/spool number P3090...
I find parts available for this type bearing in 1-1/8 axle size, but NOT the 6-1/2" length I need...
This is on a pull behind harrow I got from a friend in TN...
No name brand that I can find and "Hillbilly" says it has been on the farm since he was a young boy...
The axle was bent which in turn broke the spool/spacer/bearing where it meets the disc...
The rest of the spool appears OK...
I`m looking at putting it back together as is and see IF the parts will hold the disc in place...
I`ll try the link in the first post by copying & pasting to see IF that link works...
Thank You all for putting up with my inexperience,
Dennis
