Re: Sherman 54 B or C backhoe compatible with Ford 850?
Posted by Kirk-NJ on July 29, 2020 at 09:09:33 [URL] [DELETE] :
In Reply to: Re: Sherman 54 B or C backhoe compatible with Ford 850? posted by Paul on July 29, 2020 at 07:07:44:
My 640 does have a 4 speed with sherman combo. The sherman in step up range will spin the pto pump faster and give you a quicker response. My friend Bill has Bruce Dorsi's old 54B sherman backhoe on an 8n. I can see if the frame hook up is similar to my 640 hookup. I know his pump was 1 1/8 pto shaft as mine is too. Part of the production run in 1957 the shafts were changed to the standard 1 3/8 shaft something else you may consider if yours is a later 850
