Re: You screen, we all screen?
Posted by K.LaRue-VA on July 29, 2020 at 14:35:25 [URL] [DELETE] :
In Reply to: You screen, we all screen? posted by Brad on July 26, 2020 at 11:43:10:
I've never used anything on mine other than the replacement screen and cork gasket sold by just8ns.com. The screen fits right and the cork gasket works. A replacement valve came with a black (rubber?) coated gasket that looked better, but leaked. I replaced with original type cork gasket and it has not leaked since. Most of the time I can remove and dump the sediment bowl, no problem. Once in a while a bit of cork will pull out with the glass. Watch for that, when it happens, it will leak unless the old cork is thoroughly cleaned out and replaced with a new one. If gasket glue is needed, there is a problem. Look for any particle of old gasket material that may have been missed.
