Re: Golden Jubillee hydrolic pump
Posted by Tim Daley(MI) on July 30, 2020 at 08:21:40 [URL] [DELETE] :
In Reply to: Golden Jubillee hydrolic pump posted by Phil Ryalls on July 30, 2020 at 07:12:01:
Yes. It is always best to rebuild the OEM parts on these old vintage machines. Major components like the carb, distributor, starter, generator, water pump, hyd pump, steering, and more can be rebuilt. They were designed to be rebuilt over and over. The best investments one can make for any tractor owner are the Essential Manuals and read religiously. You should have copy of the OEM Owner/Operator’s Manual, a copy of the 39-53 MPC (Master Parts Catalog), a copy of the 53-59 MPC, and a copy of the Clymer I&T FO-19 Manual. The FO-20 has more on the 134 CID engine as well. There is also an OEM FORD SERVICE MANUAL that was supplied for technicians at the Ford Tractor Dealerships. All of these are available at Dennis Carpenter Reproductions.
FORD OEM NAA TRACTOR OWNER MANUAL:
CLYMER/I&T FO-19 SHOP REPAIR MANUAL – FORD NAA ’53-’54:
FORD TRACTOR 1939-1953 MPC:
FORD TRACTOR 1953-1959 MASTER PARTS CATALOG:
Tim *PloughNman* Daley(MI)
