8N Wheel Repair
Posted by Charles Hudson on August 03, 2020 at 13:48:24 [URL] [DELETE] :
I am replacing the OEM rear rims which are 28 inch diameter, 9 inch width, 6 loops. The tire was a 28x11.2. At least one rim has corroded beyond repair.
Replacement rims I have found are all 28x11. My question is: Are these suitable replacements, or will I encounter a problem using them with the original center hubs? Can I use a 28x11.2 tire with them or will the rim be too wide to seat the bead?
