Re: Sediment Bowl
Posted by KCM on August 03, 2020 at 17:21:44 [URL] [DELETE] :
In Reply to: Sediment Bowl posted by Sam (MN) on August 03, 2020 at 12:43:41:
Are you talking about the flat screen between the bowl and shutoff housing, or the tube screen around the pipe that goes into the fuel tank? The screen above the bowl can be purchased separately, usually along with a gasket, but the screen around the tube is part of the shutoff assembly and cannot be purchased separately. For the tube screen you would need to fabricate something yourself and solder it to the housing.
