Re: Axle Hub Removal Issue
Posted by Charles Hudson on August 13, 2020 at 12:42:45 [URL] [DELETE] :
In Reply to: Re: Axle Hub Removal Issue posted by Gaspump on August 13, 2020 at 10:31:07:
Success! Cranked a few more turns on the puller and heated the bejeezus out of the hub: kept at it until the axle nut and washer were glowing and eventually it popped loose. This was not a job for your Bernz-O-Matic torch.
BTW- Read and observe the caution in the "how to": loosen the axle nut but do not remove it from the axle. When the hub does let go it comes off with whatever force the puller has applied, i.e. lots.
Thanks to all for their suggestions.
-CH-
