Re: Thermostat
Posted by Bruce ( VA) on August 19, 2020 at 17:26:40 [URL] [DELETE] :
In Reply to: Thermostat posted by Robert Angney on August 19, 2020 at 16:20:16:
The old one should slide out.
No need to replace it unless you want to install a 180* t-stat. Which I recommend.
See tip # 25 at the link.
If you want to use a 180* t-stat (which I use on all 4 of my 8N's) try A&I part # A-11C15, Gates 33108, Beck/Arnley part # 143-0024, Auto Zone part # 3518 or NAPA part number THM 184 for 180* in hose t-stats.
The car parts store folks are helpless w/o vehicle make/model/year info.
Some can/will actually search on the number & cross reference, but more often than not, you will just get a dumb look. HINT: find a clerk near the age of your tractor..... ;) Try telling them that the t-stat is for your 1977 Renault R12 1.6L L4.
All of my 180* t-stats are A&I A-11C15's or AZ-3518's. They are a very tight fit in an N hose, but they will fit. I've never used the Gates, Beck/Arnley or NAPA t-stats so I can't help you w/ anything there but the part numbers.
All that being said.....if you do not consistently run the tractor to operating temp, you will get condensation & sludge as a result.
http://www.rockauto.com/catalog/moreinfo.php?pk=2582642&cc=1264609
http://www.napaonline.com/Catalog/CatalogItemDetail.aspx?R=THM184_0293180243
