Re: Thermostat
Posted by Bruce(OR) on August 20, 2020 at 18:31:29 [URL] [DELETE] :
In Reply to: Re: Thermostat posted by Robert Angney on August 20, 2020 at 16:52:42:
Easy way is once the thermostat is out, temp replace the upper hose, fill with water and fire it up. You should see water movement in the radiator. Water level should just slightly cover the fins to see the best action.
