Re: 841 12 Volt Conversion Questions
Posted by Bruce(VA) on August 26, 2020 at 11:54:16 [URL] [DELETE] :
In Reply to: 841 12 Volt Conversion Questions posted by Jerry on August 26, 2020 at 11:34:40:
As Jesse said.....you do not know if you have a coil problem and chances are you don't.
With the points open, you should see battery voltage (12.65 volts) at the coil and distributor.
