Re: How far to go on a restore
Posted by Ultradog MN on August 30, 2020 at 09:34:16 [URL] [DELETE] :
In Reply to: How far to go on a restore posted by Barry on August 30, 2020 at 01:43:39:
As has been said, do a compression test. Also, what oil pressure readings are you getting from it - hot and cold. If both are acceptable why rebuild the engine? You said yourself that you don't use it much.
